Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Exporting 2d voltage date to CSV from Ansys Maxwell › Reply To: Exporting 2d voltage date to CSV from Ansys Maxwell
July 16, 2024 at 3:38 pm
GLUO
If this is just a Z directional plane, it would be simple to export the field data using field calculator. You could note down the X Y range and the Z value of this plane, go to Maxwell 3D>>Field>>Field Calculator, copy the field expression you would like export to stack, export, then use the XYrang and Z value for the data to export.
GL
