Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › How to specify the “signif” parameter of CQC command in Workbench Mechanical › Reply To: How to specify the “signif” parameter of CQC command in Workbench Mechanical
July 16, 2024 at 3:19 pm
danielshaw
Access to the "signif" parameter in not exposed in the Mechanical UI. You need to specify it using the CQC command in a Command Object.
You cannot specify a different signfi per direction. It is one global setting.
