Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Total pressure is not equal to the sum of static pressure and dynamic pressure. › Reply To: Total pressure is not equal to the sum of static pressure and dynamic pressure.
xukai214
Thank you for your advice. I have set the operating density as zero and run on the calculation. The static, dynamic and total pressure along with velocity on the 4 boundaries are shown in Figure 7. The above settings seem not to work and problems remain unresolved.
Figure 7 The static, dynamic and total pressure along with velocity on the 4boundaries.
