Ansys Learning Forum Forums Discuss Simulation General Mechanical Convergence problem when going from 2023 R1 to R2 Reply To: Convergence problem when going from 2023 R1 to R2
Ashish Khemka
Hi Simon,
You can compare the input files - ds.dat for both the analysis. Right click on solution information and you will be able to see a file named ds.dat which is the input file to the solver. Comparing them will give you an idea on what is different in the setup for both the analysis.
Ashish Khemka
