Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Total pressure is not equal to the sum of static pressure and dynamic pressure. › Reply To: Total pressure is not equal to the sum of static pressure and dynamic pressure.
Can you set the operating density as zero and run on. Then report the static, dynamic & total pressure along with velocity on the 4 boundaries.
