Ansys Learning Forum Forums Discuss Simulation Fluids Cyclic sectons at different periods Reply To: Cyclic sectons at different periods
OK. So can you assume an external HTC and model just the combustor? Then map the flux onto the channel model. Running two domains can be problematic, and unless you've run the model do you know how periodic the combustor actually is? Remember that opposing jets tend to interact in interesting and unexpected ways.Â
