Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Total pressure is not equal to the sum of static pressure and dynamic pressure. › Reply To: Total pressure is not equal to the sum of static pressure and dynamic pressure.
xukai214
The pressure between the different outlets is almost the same. (Show in Figure 4) The velocity magnitude of inlet is around 10m/s and outlets is 43.6m/s. The mass average velocity on inlet and different outlets is shown in Figure 5.
Figure 4 The pressure of different outlets
Figure 5 The mass average velocity on inlet and outlets
We use equation in Figure 6 to calculate the hydrostatic pressure, the value is 959.65Pa. Previously, we compared calculations with gravity on and off and the results do not show a significant difference. So we think hydrostatic pressure is not the main reason of the problem.
Thanks again for your reply and look forward to hearing new from you!
Figure 6 The calculation of hydrostatic pressure
