Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Loss from source for Si3N4 › Reply To: Loss from source for Si3N4
Guilin Sun
What the wavelength is this? have you checked the material fitting and see if there is loss from the material? usually this material has very small loss, From the screenshot, it seems the mode has some leakage. Please use log scale to check.
This might be due to mode source size is small, or there is another material, or the PML is too thin that causes some refelction. Please check and modify the settings. If problem still exists, please give more screenshots regarding to the waveguide and simulation settings.
As for the material data, they are from different labs so it is hard to say the reasons of the difference. Maybe the material provider is not the same, or the measurement accuracy or method are not the same. You can simply pick one that fits you, and compare the results with other materia data. If the difference is large, you may either measure the material in your lab, or manufacture the waveguide and check the propagation loss against the simulation.
