Ansys Learning Forum Forums Installation and Licensing Ansys Products Error connecting to license server Reply To: Error connecting to license server
randyk
Hi Ranga,
Please confirm - these two commands continue to fail:
file /cm/shared/apps/ansys/v241/licensingclient/linx64/lmutil
/cm/shared/apps/ansys/v241/licensingclient/linx64/lmutil -v
'file lmutil' should result in:  /lmutil: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.18, stripped
'lmutil -v' should result in: Copyright (c) 1989-2023 Flexera. All Rights Reserved. lmutil v11.19.4.2 build 291863 x64_lsb
thanks
Randy
