Ansys Learning Forum Forums Discuss Simulation Fluids Total pressure is not equal to the sum of static pressure and dynamic pressure. Reply To: Total pressure is not equal to the sum of static pressure and dynamic pressure.
How does the pressure compare on each outlet? What is the mass average velocity on inlet & outlet?
Can you check what hydrostatic pressure would be over the domain?
