Ansys Learning Forum Forums Discuss Simulation Electronics Vias in AEDT Icepak Reply To: Vias in AEDT Icepak
Yannis
Hi Mert,
What kind of ECAD import are you making? In general, the vias are not visible but are considered when the conductivity is calculated. You can see the vias per layer when you are showing the metal fractions in the PCB component definition.
Kind regards,
Yannis
