Ansys Learning Forum Forums Discuss Simulation Fluids Particle overlap Reply To: Particle overlap
Lucas Bertollo Baggio
Hello Kiran,
You might enable the Collect Contacts Data checkbox from the Contacts entity and access this info through the Overlap grid function from the Contacts | Properties tab.
It shows the overlap length for each particle.
best regards,
Lucas
