Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Turbulent Twophase flow divergence › Reply To: Turbulent Twophase flow divergence
July 15, 2024 at 10:57 am
Can you restart from a saved data set and run beyond the failure point? If not, review the flowfield to see what's going on. How does the fluid temperature & velocity look, are you at risk of drying a section of the wet domain out? Ie is the solution heading towards a result where something could change very quickly?
