Ansys Learning Forum › Forums › Installation and Licensing › Ansys Free Student Software › How to set non-Newtonian fluids in the turbulent flow mode? › Reply To: How to set non-Newtonian fluids in the turbulent flow mode?
There's a TUI (Console) command in the Fluent User's Guide to activate the option: check both material property & turbulence sections. However, if the fluid is nonNewtonian do you expect the flow to be turbulent?
