Ansys Learning Forum Forums Discuss Simulation Fluids Compressibility effects causing floating point error, non-premixed combustion Reply To: Compressibility effects causing floating point error, non-premixed combustion
It means that something in the flow field is unstable with variable density and needs to be looked at. If you check the flow field what is different between the two cases?
