Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Representation of a property(for example Hardness) in the ansys post processing. › Reply To: Representation of a property(for example Hardness) in the ansys post processing.
July 15, 2024 at 9:18 am
Thanks for your response. I am not trying to use hardness values as an input but would like to show the contours on the geometry that describe the intensity plot on the 3D geometry. I have tried the method mentioned above in your discussion. I created a user-defined result and imported a file using the source in the definition; however, I am getting an error as follows:
I then tried using the file exported from ANSYS without any changes in the temperature column, but it still does not work.
