Ansys Learning Forum Forums Discuss Simulation Fluids Eulerian Wall Film Breaks Plate Heat Exchanger Model Reply To: Eulerian Wall Film Breaks Plate Heat Exchanger Model
hurch346
Thanks for the reply, I think maybe i didn't run the solver for long enough. There is 10 sub iterations per iteration, and initally i was running around 300 iterations. By running for more iterations i've noticed that my report def plots begin to increase quite late, this is making me unsure about when to stop the simulation. Would you recommend stopping when these report plots flatten out?  P.S. this is in steady-state
Thank you
