Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Two-way FSI: It’s impossible to simulate a cantilever discharging pipe in Ansys › Reply To: Two-way FSI: It’s impossible to simulate a cantilever discharging pipe in Ansys
hossein.hashemidehaghi
Thank you, Rahul. However, what should be done when the issue is a negative volume mesh in Fluent? Is there a solution besides decreasing the time step? Could the absence of very large cells impact the deformation of the elements? I ran a 1-way Fluent to mechanical. it was fine. then, I  ran another from Mechanical to Fluent, where I got negative volume meshe error after about 200 coupling steps.
