Ansys Learning Forum Forums Discuss Simulation General Mechanical Can’t showing contour at specific surface Reply To: Can’t showing contour at specific surface
mjmiddle
It's a warning, not an error. You should still be seeing a stress contour on the construction surface. It may be a systems issue if the contour doesn't show. Are you remote displaying? Maybe you should update the graphics driver. The result legend seems to think it's displaying something. If you zoom in close, do you see anything?
The warning just means you have shared topology bodies, and results displayed might be from one body or the other. You should probably go to "file > Options > Results" in Mechanical and turn on "Average Across Bodies." Or select one body at a time in the Details of the result,
