Ansys Learning Forum › Forums › Discuss Simulation › Fluids › FSI result visualization › Reply To: FSI result visualization
Emmanuel-akor
Hi Rahul, thanks a lot for this. I’ve been able to access the documentation. I see that the available Ensight result format for system coupling is (.case) and (.dvs), and I have none of that after my simulation. I read that “Ensight output will not be created if all interfaces in the analysis contain sides without regions defined. However, results are written for the interface sides containing regions”. What does this mean? My simulation has defined surfaces for the fluid inlet and all outlets, fluid wall, contact between the fluid and solid for system coupling, and the fluid region. Is there something I’m missing or didn’t include to not have the .case and .dvs files? Thanks
