Ansys Learning Forum Forums Installation and Licensing Ansys Products Error connecting to license server Reply To: Error connecting to license server
Ranga Swamy Balimidi
Hi Randy,
Thank you so much for your reply.
I’ve modified the contets of /cm/shared/apps/ansys/shared_files/licensing/ansyslmd.ini   with contents:
SERVER=1055@LicenseServerIP.
But still it runs into the same problem.
The licensing server is available at 1055 port and the windows version of Ansys works fine.
This is the first time we are setting up Ansys on Linux OS. Is there anything else we are missing to run “fluent”..?
Thanks,
Ranga.
