Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Issues trying to inflate an open airbag using a wind tunnel › Reply To: Issues trying to inflate an open airbag using a wind tunnel
Ian Do
Hello James,
I can't see how the parts are relative to each other during the inflation. Maybe a hand sketch showing the desired final config with parts all labeled will help.
Below is a simple example to follow. It is defined based on the new S-ALE approach. ALE has a steep learning curve, if you have not taken a class. If you can access ALH (ANSYS Learning Hub), pls find my ALE/S-ALE class there.
Best Regards,
Ian Do
https://ansys-my.sharepoint.com/:u:/r/personal/ian_do_ansys_com/Documents/0-SALE/SALE-examples/001-airbag/01saleairbag/02saleairbag/02saleairbag.zip?csf=1&web=1&e=ek4Cpz
