Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Connection between rigid body and flexible body (Battery Container) › Reply To: Connection between rigid body and flexible body (Battery Container)
July 12, 2024 at 4:20 pm
Few suggestions - check the contact status before and after the solution. Use MPC contact formulation for bonded contacts with surface bodies. Check if you have large deflection turned on. You can refer to the following link as well:
Verifying and Validating the Model Setup - Lesson 1 - ANSYS Innovation Courses
Ashish Khemka
