Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Poor quality mesh at trailing edge for 3d wing › Reply To: Poor quality mesh at trailing edge for 3d wing
Have a look at what sizing you're using. If you're using a mix of hard edge/surface control and size function then odd things can happen.
If the jet is likely to oscillate you may find the residuals don't drop for a steady run. That's why we use monitor points.
