Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Inxex Preview Problem › Reply To: Inxex Preview Problem
Thang Tran
Hi Amrita,
Thank you for your advice; I have found out the problem. It come from the node I chose for the z-direction. It need to be an integer number. For example, if I choose 1 node = 10 nm,  the thickness must be 10, 20, 30 nm, etc.
Thang
