Ansys Learning Forum Forums Discuss Simulation Photonics Small signal ac analysis using charge solver Reply To: Small signal ac analysis using charge solver
Amrita Pati
Hi Richa,
I was able to run the files without any issue. It could be related to your hardware specs. Would you be able to share a screenshot of the log file? It should be in the same directory, and should be named something like: "vpd_CHARGE_ssac_p0.log".
Amrita
