Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › HFSS – Electric Field on lumped port problem › Reply To: HFSS – Electric Field on lumped port problem
Jean TAPIE
Hello Jason,
Thank you for your answer.
What you wrote explains the sqrt(2) factor for the modal case. But my main concern is why the electric field is two times the supposed one in both cases (modal, terminal)?
Jean
