Ansys Learning Forum › Forums › Discuss Simulation › Preprocessing › floating point exception › Reply To: floating point exception
If you're sucking air in use a pressure boundary. What property model are you using for air density? That may determine some of the solve settings to prevent fluid "falling" through the domain.
