Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Question about time scale constant › Reply To: Question about time scale constant
July 12, 2024 at 2:13 am
Hi Rob!
All the following figures are using the RSM model.
When using 0.3, the particle trajectories are more concentrated. When using 0.15, the particle trajectories become more dispersed.
How can I determine which one is the correct particle trajectory result? Is it acceptable to set the time scale constant to 0.15 when using RSM?
Thank you so much.
