Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Solar Ray Tracing › Reply To: Solar Ray Tracing
Charles
Hi, thanks for the advice.
I discovered that as I had defined coupled wall between the car frame and enclosure, the coupled walls were treated as transparent even with solar ray tracing participation enabled. Solar ray tracing worked after the coupled wall condition was removed and the enclosure deleted.
