Ansys Learning Forum Forums Discuss Simulation Fluids ansys aqwa : ball connector and socket Reply To: ansys aqwa : ball connector and socket
nhanani4
1) what is the formula of stiffness about global x, stiffness about global y and global z should I key in?
2) I want to connect my multi-floating structure in that picture arrangement but only the ball and socket connector can run the data horizontal force. What should I do to run simulation with change the ball socket to hinge?
Thank.
