Ansys Learning Forum Forums Discuss Simulation Photonics Two cases in the case base have different brdf calculation results. Reply To: Two cases in the case base have different brdf calculation results.
jie li
Yes, I downloaded both examples to calculate the BRDF of the surface, and I found that both  have the same geometric modeling method. I tried to use the same parameters to simulation, but the BRDF results were wildly different.
I only changed the roughness to 0. and then the grid accuracy was reduced to level 1, the scanning azimuth was changed to 0 , and the index is3.84 (Si) ,  and the simulation results were as follows. the first come from “Bidirectional_scattering_distribution_function_(BSDF)”
The second figure from “Diffuse Scattering Film for Automotive Display”, which has the same simulation parameters as the first, i got the result by clicking “run”, and running the analysis script.
