Ansys Learning Forum › Forums › Discuss Simulation › Fluids › DO radiation model › Reply To: DO radiation model
July 11, 2024 at 2:36 pm
Hi
Could you please elaborate the 1st question. To break down the total radiation data into different wavelengths in the Fluent Discrete Ordinates (DO) radiation model, you can specify a non-zero number of bands in the Radiation Model dialog box. This will allow you to define individual wavelength bands, each with a specified start and end wavelength. The model will then compute the radiation for each of these bands, assuming gray behavior within each band. You can specify different material properties for each band as well.
