Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Fluent crashing › Reply To: Fluent crashing
July 11, 2024 at 8:53 am
6M cells will be very tight on 16GB RAM. You might get away with single precision but possibly not. The slowdown indicates you're paging to disc, the noise used to be a good indicator of this but with SSDs this is nolonger a check. If you can access a bigger machine you can check memory requirements before upgrading.Â
