Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Convergencia › Reply To: Convergencia
It suggests that the default number of iterations was not sufficient to initialize the velocity and pressure fields to the desired level of accuracy. To address this, you can increase the number of iterations in the General Settings tab of the Hybrid Initialization Dialog Box. This may be particularly necessary for complex and highly curved geometries. For complex and highly curved geometries, if the default number of iterations is not enough to reach the convergence tolerance of 1e-06 and the flow fields are not to your liking, then you may want to increase the number of iterations and re-initialize the flow.
For more details, please check fluent user's guide: 35.11. Hybrid Initialization (ansys.com)
Thank you
