Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Two cases in the case base have different brdf calculation results. › Reply To: Two cases in the case base have different brdf calculation results.
Amrita Pati
Hi Jie,
Are you calculating the BSDF from the files given in these 2 examples? I am supposing it could be the data format, as the 2nd one is supposed to be consistent with Spoes. But let me test it and get back to you.
Amrita
