Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › How do I apply a radial displacement to an element to compress another element › Reply To: How do I apply a radial displacement to an element to compress another element
July 10, 2024 at 11:52 pm
A radial displacementy should work by setting the x value of a displacement that uses a cylindrical coordinate system, as long as rotation does not occur around the cylindrical Y axis. But it seems by the shape, you would really want a spherical direction for displacement, and Mechanical doesn’t allow you to create a spherical coordinate system.
You seem to be describing a press fit model. We don’t handle these by prescribing a fixed radial displacement. We model press-fit two ways:
- Model the geometry in the dimensions before assembly. When the bodies are placed together, there will be an interfence and you will use a contact. The analysis will deform both bodies into touching status, and in so doing, it computes the press-fit stress and strain. The interference should be within the first layer thickness of the volume elements at the contact.
- Model geometry as touching, and specify an offset distance in the contact Details that would be the interference distance of the assembled bodies before press-fit occurs. The analysis will deform the geometry and compute stress/strain just like method 1.
