Ansys Learning Forum Forums Discuss Simulation General Mechanical Meshing thickness of the shell (Surface from Faces) Reply To: Meshing thickness of the shell (Surface from Faces)
peteroznewman
With just a surface model in geometry, bring that into Mechanical.
 Mesh the surface with shell elements, then insert a Mesh Edit for Pull (Extrude) to get 4 elements through the thickness.
