Ansys Learning Forum › Forums › Discuss Simulation › Fluids › ansys aqwa : ball connector and socket › Reply To: ansys aqwa : ball connector and socket
July 10, 2024 at 3:59 pm
The items in the Joint Properties are optional. If there is no data being typed in, the default is zero. For a ball and socket joint, its joint local axes coincide with the axis directions of the global coordinate system axes at the initial definition localtion.
