Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Method to observe analysis result at each time step › Reply To: Method to observe analysis result at each time step
Aurojyoti Prusty
I suppose you are doing a static structural problem and applying multiple load at different load step.
After application of load in multistep, add stress, strain, deformation (directional or total) to the solution field and solve the model.
Results from each load step (min, max, avg) will be available in each result like graph below (4 steps). Please let us know if this helps or you meant something else in the question.
Thanks,
Aurojyoti
