Ansys Learning Forum Forums Discuss Simulation General Mechanical Harmonic analysis of a beam in water using HROCEAN Reply To: Harmonic analysis of a beam in water using HROCEAN
dlooman
Your results seem to be all zero.  Here's a qa test.  Maybe you can modify it to do what you want.
/title,ocha-4s,vkumar,verify hrocean harmonic loading,PIPE288
/COM,***************************************************************************
/COM, TEST OBJECTIVE: Perform harmonic analysis on PIPE288 using HROCEAN command
/COM,
/COM,
/COM, ELEMENTS: PIPE288(KEYOPT(12)=3)
/COM,
/COM, MATERIAL: ELASTIC
/COM,
/COM, DESCRIPTION:
/COM, A vertical tube consisting of only one element fully submerged
/COM, in water is constrained in all degrees of freedom at bottom node.
/COM, The wave loading is applied to the model and harmonic analysis is
/COM, performed using the ocean wave table to extract the reactions and
/COM, tip displacements.The data base of case1 is saved and reused in case2.
/COM,
/COM,
/COM, Case1: The wave is applied and harmonic analysis is done with
/COM,        HROCEAN,HARMONIC command using ocean wave table
/COM,
/COM,
/COM, Case2: The real and imaginary forces of the wave obtained from
/COM,        Case1 is applied at nodes to same model using keyopt(12)=2
/COM,        and by setting a tiny wave height in ocean wave table. Ocean
/COM         environment is deleted using HROCEAN,OFF and by not issuing
/COM,        ocean id to pipe section. The harmonic analysis is performed
/COM         at wave excitation frequency using HARFRQ.
/COM,
/COM, Expected Results: 1. The reactions and tip displacements obtained
/COM,                      in complex form  from Case1 and Case2 should match.
/COM,
/COM, CASE 1:Harmonic analysis using HROCEAN,HARMONIC
/out,scratch
/COM, Input Parameters
noe    =1                             ! number of elements
pi     =3.14159265                    ! circumference/diameter of a circle
L      =100                           ! length of pipe
ER     =2.10e+11                      ! Young's modulus of pipe
PRATIO =0.0                           ! Poisson's ratio
Do     =0.533                         ! outer diameter of pipe
Di     =0.508                         ! inner diameter of pipe
Thk    =(Do-Di)/2                     ! thickness of pipe
RHOP   =0.00000030                    ! density of pipe
RhoW   =1025.0                        ! density of water
Cd     =1.0                           ! drag coefficient
Cm     =1.0                           ! inertia coefficient
Depth  =100.0                         ! depth of ocean
H      =4.0                           ! height of wave
T      =10.0                          ! time period of wave
sfvel  =0.2                           ! velocity of current at top surface
depvel =0.3                           ! velocity of current at ocean floor
NPHASE =8
/PREP7
/COM, Material properties
MP,EX  ,1,ER
MP,PRXY,1,PRATIO
MP,DENS,1,RhoP
MP,DENS,2,RhoW
/COM, Element and keyopts
ET,1,PIPE288
KEYOPT,1,12,3
KEYOPT,1,15,0
KEYOPT,1,6,1
/COM, Section properties
SECTYPE,1,PIPE
SECDATA,Do,Thk
/COM, Finite element modeling
N,1,,,-90
N,2,,,-L
E,1,2
SAVE,,DB
/COM, Ocean Basic data
OCTYPE,BASIC
OCDATA,Depth,2,,0,,0
OCTABLE,,,Cd,,0,Cm
/COM, Ocean Wave data
OCTYPE,WAVE
OCDATA,0                  ! Small Amplitude Airy Wave theory
OCTABLE,H,T,0
FINISH
/SOLU
ANTYPE,HARM
ACEL,,,9.8
D,2,ALL
TIME,1e-011
HROCEAN,HARMONIC,NPHASE
OUTRES,ALL,ALL
OUTPR,ALL,ALL
SOLVE
FINISH
/POST26
ESOL,2,1,1,f,x,FX_1
ESOL,3,1,1,f,z,FZ_1
ESOL,4,1,2,f,x,FX_2
ESOL,5,1,2,f,z,FZ_2
NSOL,6,1,U,X,UX_TIP
PRVAL,2,3,4,5,6
EXTREME,2,5,6
FINISH
/POST1
SET,1,,,real
PRNLD,F
SET,1,,,imag
PRNLD,F
SET,1,,,real
PRRSOL,F
*GET,FX1_REAL,NODE,2,RF,FX,REAL
*GET,UX1_REAL,NODE,1,U,X,,REAL
SET,1,,,imag
PRRSOL,F
*GET,FX1_IMAG,NODE,2,RF,FX,IMAG
*GET,UX1_IMAG,NODE,1,U,X,,IMAG
FINISH
PARSAVE
PARRES
/out,
/COM************************************************************
/COM Expected results: The reaction forces and tip displacements
/COM                   for case 1 and 2 should match
/COM Real reaction for case 1
  *STATUS,FX1_REAL
/COM Imaginary reaction for case 1
  *STATUS,FX1_IMAG
/COM Real component of displacement for case 1
*STATUS,UX1_REAL
/COM Imaginary component of displacement for case 1
*STATUS,UX1_IMAG
/CLEAR,NOSTART
/COM, CASE 2:HROCEAN,OFF and HARFRQ
PARRES
/out,scratch
/PREP7
RESUME,,DB
OCTYPE,BASIC
OCTABLE,,,Cd,0,0,Cm
OCTYPE,WAVE
OCTABLE,1e-011,1e+11,0
/SOLU
ANTYPE,HARMIC
HROCEAN,OFF
OCDELETE,all !2,3,1
HARFRQ,0,1/T
ACEL,,,9.8
NSUBST,10
TIME,1e-11
F,1,FX,1.9901,-33.470
F,2,FX,1.8871,-32.592
D,2,ALL
OUTRES,ALL,ALL
SOLVE
FINISH
/POST26
NUMVAR,100
ESOL,12,1,1,F,X
ESOL,13,1,1,F,Z
ESOL,14,1,2,F,X
ESOL,15,1,2,F,Z
NSOL,16,1,U,X,UX_TIP
PRVAR,12,13,14,15,16
FINISH
/POST1
FLIST
SET,1,,,real
PRNLD,F
SET,1,,,imag
PRNLD,F
SET,1,,,real
PRRSOL,F
*GET,FX2_REAL,NODE,2,RF,FX,REAL
*GET,UX2_REAL,NODE,1,U,X,,REAL
SET,1,,,imag
*GET,FX2_IMAG,NODE,2,RF,FX,IMAG
*GET,UX2_IMAG,NODE,1,U,X,,IMAG
PRRSOL,F
FINISH
PARSAVE
PARRES
/out,
/COM Real reaction for case 2
  *STATUS,FX2_REAL
/COM Imaginary reaction for case 2
  *STATUS,FX2_IMAG
/COM Real component of displacement for case 2
*STATUS,UX2_REAL
/COM Imaginary component of displacement for case 2
*STATUS,UX2_IMAG
/EXIT,NOSAVE
