Ansys Learning Forum Forums Discuss Simulation Preprocessing floating point exception Reply To: floating point exception
Have a look at the mesh. Just because the cell quality is (just about) acceptable doesn't mean the mesh is appropriate. You need to resolve the flow in the domain so where you have 3-4 cells across the duct/tunnel isn't good enough. You may want to review splitting surface in the geometry tool too as I don't think you need the stubs on the outlet.
