Ansys Learning Forum Forums Discuss Simulation General Mechanical Import Parameterized Function (curve) from Solid Works to Workbench ? Reply To: Import Parameterized Function (curve) from Solid Works to Workbench ?
Gary_S
Hello
The SolidWorks plugin is capable of importing Global Variables which can then be driven from within the Ansys Parameters.
In my example here, a simple Global Variable "a" is exposed to the Parameter set. Note I had to change my parameter filter to include "a" so anything with "a" in the name will pass into Ansys.
The question for SW support is: Can you drive your X1 or X2 parameters with an equation value such as "a".
If yes, then it seems you can accomplish your task.Â
