Ansys Learning Forum Forums Discuss Simulation Fluids ANSYS fluent – Rocky DEM coupling Reply To: ANSYS fluent – Rocky DEM coupling
So try dropping the time step in Fluent to make sure it's low enough.
To check the mesh replot the above with node values off - you need to do that in Fluent's post processing. You're then looking to see how well resolved the velocity gradients are.
