Ansys Learning Forum Forums Discuss Simulation General Mechanical Moment of inertia and Centre of gravity Reply To: Moment of inertia and Centre of gravity
ashish.khemka
Hi Deepesh,
You can input moment of inertia values for each direction when defining a Point Mass in Ansys Mechanical Application. This allows you to idealize the inertial effects from a body using a Point Mass, which can affect modal and harmonic solutions. The location of the Point Mass can be anywhere in space and can also be defined in a local coordinate system if one exists.
 https://ansyshelp.ansys.com/Views/Secured/corp/v232/en/wb_sim/ds_point_mass.html
Ashish Khemka
