Ansys Learning Forum › Forums › Discuss Simulation › Fluids › MHD model for simulating ionic wind with negligible magnetic force? Or Maxwell? › Reply To: MHD model for simulating ionic wind with negligible magnetic force? Or Maxwell?
HDLI
Hello hala albukai,
     a). In Maxwell electrostatics solver, we could use parameter> force, to get total force in the electrical field, or use filed calculator to calculate surface or volume force.
     b). I am not sure what is the application. MHD model would always use magnetic excitation in coupling between Maxwell and Flunet. Do you have the magnetic excitation? If using electical field, could you try to find Ansys EMA3D?
HDLI
