Ansys Learning Forum › Forums › Discuss Simulation › Fluids › UDF describing the relationship between pressure loss and mass flow rate › Reply To: UDF describing the relationship between pressure loss and mass flow rate
July 9, 2024 at 12:55 pm
Not easy as the data access macros are mostly velocity based as Fluent solves for momentum. The fluxes will be available, but you'd then potentially be messing with momentum sinks as you wouldn't set a pressure loss.Â
You may need to review what data you have and then rethink the modelling approach.Â
