Ansys Learning Forum Forums Discuss Simulation Fluids particle phase volume fraction problem with Fluent-Rocky coupling Reply To: particle phase volume fraction problem with Fluent-Rocky coupling
Check how the coupling is set up as Rocky may be passing the volume fraction back as a flow resistance and you should be looking in the UDMs for volume fraction.
