Ansys Learning Forum › Forums › Discuss Simulation › Fluids › UDF for calculating the phase fraction based volume › Reply To: UDF for calculating the phase fraction based volume
July 9, 2024 at 11:11 am
If you're using VOF which implies most of the cells should be one phase or the other can you not use a volume integral report?
