Ansys Learning Forum Forums Discuss Simulation Fluids Proposal for fast fluent grid generation for modeling with many objects Reply To: Proposal for fast fluent grid generation for modeling with many objects
Jeongwon Lee
My suggestion is that once you setup named selections in workbench meshing and then generate surface mesh only. (mesh -> Preview -> surface mesh)
If your surface mesh is generated successfully, export this surface mesh file for Fluent (File > Export > Mesh > Fluent input file)
Now you can read this surface mesh file using Fluent meshing Watertight Geometry Workflow. You can find boundary and cell zones assigned as NS in WB meshing.
Hope this is helpful.Â
